November 6, 2026 at 5:50 pm #114794
Why Telecom Power Systems Need a Custom 48V LiFePO4 Battery Approach
Telecom power systems operate under some of the most demanding electrical and environmental conditions in B2B infrastructure. Equipment manufacturers and system integrators sourcing a 48V LiFePO4 battery for telecom power systems often discover that generic battery packs cannot satisfy the specific combination of voltage stability, capacity, load current, BMS functionality, and physical integration that their devices require. This is the core industry pain point that Shanghai Mylion New Energy Co., Ltd., operating under the brand MYLION, was built to address. Rather than selling standardized packs at low prices, MYLION positions itself as an engineering-driven B2B lithium battery solution provider focused on custom battery-pack development and project execution, prioritizing technical integration over low-price retail sales.
Understanding the Engineering Challenge Behind 48V LiFePO4 Packs
A 48V LiFePO4 configuration is not simply a matter of stacking cells to reach a target voltage. According to MYLION’s engineering framework, many B2B customers cannot utilize generic battery packs due to highly specific requirements for voltage, capacity, load current, BMS functions, cell chemistry, physical dimensions, connectors, and environmental safety certifications. For telecom power systems specifically, this means the battery must be evaluated as an integral part of the customer’s entire system—considering the real load, charging source, BMS functions, mechanical interfaces, and production constraints rather than treating electrical parameters in isolation. This systems-level view is central to MYLION’s value proposition: converting complex device requirements into technically reviewed, validated, and produced battery packs through a controlled engineering process to reduce selection errors, thermal issues, and certification delays.
MYLION’s Project-Based Development Process for Custom LiFePO4 Solutions
MYLION’s Custom LiFePO4 Battery Pack Solutions are developed through project-based engineering where discharge capability, charging methods, and environment are confirmed for the final device before production begins. This addresses a common failure point in the industry: generic LiFePO4 replacements causing charger or BMS incompatibility due to lack of system review. For telecom applications, where power continuity and backup reliability are critical, this review process is particularly valuable.
The development pathway includes several differentiated stages. First, chemistry review involves scenario validation to confirm LiFePO4 appropriateness for the specific operating conditions of the telecom equipment. Second, electrical architecture review determines the series/parallel configuration from energy and runtime targets, which is directly relevant when a customer specifies a 48V output requirement. Third, validation before production ensures project-defined testing is conducted based on final approved specifications, rather than relying on generic test standards that may not reflect real-world telecom load profiles.
This process is supported by MYLION’s broader Custom Lithium Battery Pack Development framework, which spans requirement definition through mass-production support. Target scenario pain points addressed include incomplete or conflicting requirements regarding peak load, runtime, BMS functions, or mechanical structure—issues that can lead to project failure if not identified early.
Key Technical Capabilities Supporting 48V LiFePO4 Battery Packs
MYLION’s technical capabilities are directly applicable to telecom power applications requiring a 48V LiFePO4 battery. These include custom series/parallel configuration to achieve the required voltage and capacity targets, BMS matching for balancing, monitoring, and protection functions, and specific current/peak-load management suited to telecom load characteristics. The company’s technology platform includes expertise in LiFePO4 chemistry alongside 18650/21700 cylindrical cells and LiPo architectures, allowing format selection to be matched to the physical and thermal constraints of telecom cabinets or outdoor enclosures.
Key features relevant to telecom customers include custom voltage and capacity definition that matches electrical targets to approved requirements, chemistry selection based on project conditions, BMS matching through protection and communication function evaluation, connector and interface customization for chargers, cables, and pinouts, and mechanical integration covering enclosure, mounting, and insulation design. Project-defined architecture replaces standard voltage assumptions with custom pack design, while load matching aligns continuous and peak current to real device loads—an essential consideration for telecom backup power that must respond to variable draw conditions.
Industry Applications and Validated Use Cases
Communication and network equipment is explicitly listed among the industries MYLION covers, alongside electronic and professional equipment, smart home and IoT devices, industrial instruments, robotics and automation, security and monitoring systems, agricultural and field-use equipment, and portable tools. Within its documented customer cases, MYLION has provided stable output and robust connectors for professional instruments to prevent BMS trips and voltage drops in industrial equipment settings—a reliability concern that translates directly to telecom power infrastructure, where voltage drops and unexpected BMS interruptions can compromise network uptime.
MYLION’s customer base includes equipment manufacturers, product brands, industrial electronics companies, system integrators, and regional distributors, reflecting the diversity of B2B buyers who require application-specific battery engineering rather than off-the-shelf products.
Quality, Compliance, and Long-Term Supply Assurance
For telecom power systems, safety documentation and supply consistency are as important as electrical performance. MYLION supports UN38.3 transport documentation and provides MSDS/SDS safety data sheets, giving customers the compliance documentation needed for international shipment and regulatory review. Service assurance mechanisms include change-control management, version-controlled BOMs, and repeat-order supply coordination, which help telecom equipment manufacturers maintain consistent specifications across production runs and future orders.
MYLION’s delivery models include OEM, ODM, Private Label, and controlled mass-production delivery, structured through stages from requirement confirmation to production-readiness and repeat-order support. After-sales support includes change management review and approved specification control, ensuring that once a 48V LiFePO4 configuration is validated, it remains consistent across subsequent production batches—a critical factor for telecom operators managing fleets of distributed power equipment.
Why Choose a Custom Engineering Partner for Telecom LiFePO4 Power
With over 13 years of lithium battery industry experience, MYLION has evolved from standard battery-pack supply to a structured custom-battery engineering model emphasizing requirement definition, sample validation, and controlled specifications. Headquartered in Shanghai, China, and serving global B2B markets, the company functions as an OEM/ODM project partner rather than a generic component seller. Pricing follows a project-based quotation approach, applied only after technical requirement confirmation and feasibility review, ensuring that cost estimates reflect the actual engineering scope of each telecom power project.
For organizations evaluating a 48V LiFePO4 battery for telecom power systems, the combination of requirement engineering, system-level matching of battery, BMS, charger, and mechanical structure, and risk control through early identification of technical blockers positions MYLION as a project partner capable of translating telecom-specific power requirements into validated, production-ready battery solutions.
Shanghai Mylion New Energy Co.,Ltd. -
