30, 60, 90 or 120 Minutes: How to Read a Fire Rating on a Cable Tray Datasheet
  • #114850
      Every fire rated cable tray quotation arrives with a rating line: "2 hours fire rated", "F1 class", "120-minute system". Most of those lines collapse the moment a reviewing engineer asks one question — tested how, by whom, on what assembly? How many minutes fire rating does a cable tray need is only half of the buying decision; the other half is whether the number on the datasheet would survive a site inspection. This guide reads the rating line the way an auditor does: what the duration must cover, which five lines of the datasheet have to agree with each other, and how to verify fire test report from cable tray supplier documents before the purchase order goes out.
      Reviewing a fire rating on a cable tray datasheet against a coated tray sample
      1. How many minutes fire rating does a cable tray need?
      The duration follows the circuit, and the circuit is on the drawings, not in the catalogue. Across hospital, metro, commercial and industrial work, these are the durations we see specified:
      ✅ Fire alarm loops — 30 to 60 minutes
      ✅ Emergency lighting — 60 to 90 minutes
      ✅ Fire pump and sprinkler supply — 90 to 120 minutes
      ✅ Smoke extraction fans, firefighter lifts — 120 minutes
      ✅ Hospital critical supply — 120 to 180 minutes
      A datasheet that offers a single duration for every application is describing one product, not your project. Once the required duration is known, it converts to a class letter: under GB 29415-2013, the fire resistance rating F1 F2 F3 F4 cable tray meaning is a minimum tested duration of 90, 60, 45 and 30 minutes respectively, measured on the complete assembly. We keep the full class definitions and the international equivalents — DIN 4102-12, BS 476, UL 2196 — in our F1–F4 rating guide; this article stays on the paperwork.
      ✅ Bottom line: Fix the duration from the circuit schedule first. Only then can a datasheet be judged right or wrong.
      2. The five lines that must agree on the datasheet
      A credible rating is never one line. It is five lines, and they have to be consistent with each other:
      ✅ Duration — 30, 60, 90 or 120 minutes, stated as a tested result, not a design intention.
      ✅ Test standard and laboratory — GB 29415, DIN 4102-12, BS 476-20/21 or UL 2196, with the laboratory named.
      ✅ Coating dry film thickness — typically 1.4 to 1.6 mm for F3, 1.8 to 2.0 mm for F2, 2.4 to 2.6 mm for F1 on steel.
      ✅ Steel sheet gauge — the rail thickness that carried the load in the fire test.
      ✅ Assembly configuration — span, support spacing, covers, splice plates: the geometry that was actually in the furnace.
      Most paper ratings fail on the pairs. A duration with no thickness cannot be checked on site. A thickness with no gauge invites a lighter supply lot. A tested span of 1.5 m quoted for supports at 2.5 m voids the result. If the vocabulary on the datasheet mixes the three tiers — flame retardant, fireproof, fire rated — send the reviewer to our article on what actually differs before the comparison continues, because a coating-only claim quoted against a system requirement is the single most common mismatch we see in cross-quotation reviews at LIWEIJU.
      3. How to verify fire test report from cable tray supplier
      The report is where a claim becomes evidence. Here is how to verify fire test report from cable tray supplier documents in under an hour:
      ✅ Trace the laboratory. A real report names an accredited body — a CNAS-accredited lab under ILAC, or UL, TÜV, Intertek, SGS. Search the report number; if it does not resolve to an issuer, it is decoration.
      ✅ Match the specimen to the order. Gauge, coating, span, covers and supports in the report must match what the factory will ship, not merely look similar.
      ✅ Check the scope language. A result on a bare panel does not cover a covered route; a 60-minute result does not stretch to a 120-minute circuit.
      ✅ Reconcile the batch record. The dry film thickness on the report must be reproducible on the delivered batch — ask for the per-lot DFT record and spot-check cut edges and bolt holes on arrival. LIWEIJU ships this record with every F-class batch.
      ✅ Date and issue status. Expired certificates, "report available upon audit" without a copy, or a scan without an issue date all fail.
      The most reliable way to verify fire test report from cable tray supplier paperwork is to ask one early question: which laboratory issued it, and will they confirm the report number directly? Genuine manufacturers answer within a day. For high-value projects, a witnessed retest of a sample from the production line settles the question permanently — an option Jiangsu Liweiju Electrical Co., Ltd. offers on custom and OEM orders, with ISO 9001 batch records behind every F-class shipment.
      ✅ Bottom line: Verify the report before the PO, not after the fire. Five lines, one laboratory phone call, one batch record.
      Fire rated cable tray batch with coating thickness record in a factory
      Frequently asked questions
      Q: Can we accept a thickness claim without a test report?
      A: No. Thickness is an input, not a result. The answer to how many minutes fire rating does a cable tray need comes from a tested assembly, and two trays with identical coating can test differently if the gauge, span or covers differ. Treat a thickness-only datasheet as a starting quotation, not a submittal document.
      Q: The supplier sent a PDF report. Is that enough?
      A: A PDF is fine — if it checks out. Confirm the issuing laboratory, the report number, the specimen configuration and the issue date. A class letter only carries the fire resistance rating F1 F2 F3 F4 cable tray meaning when the specimen matches the order, because that is where substitutions hide.
      Q: What if there is no report for our exact configuration?
      A: Ask for the closest tested configuration in writing, then decide: accept the nearest result with the fire engineer's sign-off, or commission a witnessed test on your configuration. LIWEIJU runs its own coating line and in-house QC lab, and can usually turn a witnessed sample test around within the project programme — a fair question to put to any factory you are auditing. Remember that the fire resistance rating F1 F2 F3 F4 cable tray meaning attaches to the tested assembly, so a witness test must replicate the span, gauge and coating of your actual order.
      Next step
      Send us the datasheet you are reviewing and we will mark up which of the five lines are present, which are missing, and what to ask the supplier next. No charge, no obligation. LIWEIJU is a fire rated cable tray manufacturer in China supplying OEM and custom F-class systems from 100 to 800 mm width, with batch DFT records, third-party verification and wholesale pricing available on request. Reach the factory through the LIWEIJU contact page with your datasheet and destination port, or browse the fire resistant cable tray range first.
      http://www.lwjelec.com
