1,250 kVA Generator Sets for Industrial Facilities: What a Capable Supplier Delivers With Every Unit
  • #114888
      The 1,250 kVA class sits at the heart of industrial power. It is large enough to carry a production line, a cold store or a processing plant on its own, and compact enough to fit in a single container and combine with further units as a site grows. For buyers comparing suppliers of 1,250 kVA generator sets, the nameplate rating is the starting point; what counts is how completely each unit is documented, built, tested and supported. MPMC, a Shanghai-based generator set manufacturer founded in 2008, offers this class for both 50 Hz and 60 Hz markets on its containerised platform.
      The 1,250 kVA Class in MPMC’s Range
      50 Hz: MCLS1250(S)-1
      At 50 Hz, the MCLS1250(S)-1 pairs a Cummins KTA50-G3 engine with a Leroy-Somer LSA 50.2 M6 alternator for 1,250 kVA / 1,000 kW prime and 1,375 kVA / 1,100 kW standby. In its super-silent SC container it reaches 83.4 dB(A) at 1 m and 75% load, which suits plants located beside offices or residential areas.
      60 Hz: MCLS1260(S)-2
      For 60 Hz markets, the MCLS1260(S)-2 uses the same KTA50-G3 engine with a Leroy-Somer LSA 50.2 L7 alternator, rated 1,375 kVA / 1,100 kW prime and 1,575 kVA / 1,260 kW standby. Beyond Cummins, the containerised platform is built with Perkins, MTU, Baudouin, Scania, SDEC and other engines, so each facility can match the engine to the service partners it already works with.
      Table 1. MPMC 1,250 kVA-class models (Cummins-documented)
      Model
      Frequency
      Engine
      Alternator
      Prime power
      Standby power
      MCLS1250(S)-1
      50 Hz
      Cummins KTA50-G3
      MCLS1260(S)-2
      60 Hz
      Cummins KTA50-G3
      Note: The table shows the 1,250 kVA-class models; MPMC’s Cummins-documented containerised range also includes further models from 1,000 kVA to 2,281.25 kVA prime.
      The choice between the two follows the local grid frequency and the voltage of the plant’s switchgear, and both models can be supplied as open units for plant rooms or in super-silent containers for outdoor installation.
      MPMC 1,250 kVA containerised diesel generator set powered by a Cummins engine, installed on site.
      What Comes With Every Unit
      Verified Performance
      Every set is load-tested at 0%, 25%, 50%, 75%, 100% and 110% in MPMC’s CNAS-accredited test centre, including a constant-temperature room that simulates 40°C or 50°C ambient. Documented models comply with ISO 8528-5, with steady-state frequency stability within ±0.25% and voltage regulation within ±1% to protect drives, PLCs and process electronics.
      Built for Industrial Sites
      Containers are fabricated with laser cutting, certified welding by licensed welders, NDT magnetic particle inspection of every chassis, pressure testing, sandblasting and C3, C4 or C5 anti-corrosion coating verified by 500 to 700 hours of salt spray testing. Copper radiators for 50°C ambient and built-in fuel tanks of 6, 8, 12 or 24 hours complete the specification for demanding plants.
      Controls for Backup or Parallel Duty
      DSE or DEIF controllers provide automatic mains changeover for unattended standby duty, and several 1,250 kVA units can run in parallel through ABB or Schneider motorised breakers for N+1 redundancy or to follow a plant’s expansion. Facilities that also want peak shaving can operate the sets alongside the grid or add MPMC HBD-A battery storage for millisecond response.
      Table 2. Industrial projects built on the Cummins KTA50-G3 platform used in MPMC’s 1,250 kVA class
      Project
      Capacity
      Configuration
      Mining power generation, Australia
      5.2 MW
      Cummins KTA50-G3 + Stamford S6L1D-G4; containerised
      Off-grid long-running power station, Kenya
      4 MW
      Oil and gas field camp, Saudi Arabia
      3.3 MW
      Cummins KTA50-G3 + Leroy-Somer LSA50.2 L7; containerised
      Rental construction, Saudi Arabia
      33.5 MW
      10 × 1,100 kW KTA50-G3 and 25 × 900 kW QST30-G4; Stamford S6L1D-F4
      Stadium, Mexico
      6.9 MW
      5 × 1,375 kVA, KTA50-G3 + Leroy-Somer LSA 50.2 M6; 60 Hz, 440 V
      MPMC containerised KTA50-G3 generator sets of 1,375 kVA from the 6.9 MW stadium project in Mexico.
      Why Industrial Buyers Choose MPMC for This Class
      MPMC has been the largest G-OEM in China by volume for Perkins and Stamford in recent years and has delivered products to more than 120 countries and territories. Units are built at its Haimen smart factory, a 22,000 m² facility with end-to-end CNC, fabrication and testing and CRM, ERP, PLM and MES systems, which keeps quality consistent across repeat orders for multi-site industrial groups. Each order includes design consultation, product customisation, factory testing, logistics and commissioning support, and generator sets carry a 1-year or 1,000-hour warranty, with engines, alternators and controllers supported through their manufacturers’ global service networks.
      Requesting a 1,250 kVA Proposal
      • State the frequency, voltage and duty: standby, prime or parallel
      • List the largest motor starts and step loads
      • Note noise limits and the installation space
      • Choose the engine brand and fuel autonomy
      • Contact MPMC at sales@mpmc-china.com or WhatsApp +86 150 0085 4420 for a 1,250 kVA quotation
      https://www.mpmc-china.com/
      MPMC Powertech Corp.
